01 24v VP44 to VE Swap (info gathering)
Truck:
2001 1 ton Quad Cab 4x4 6 speed HO 24v 5.9 VP44 140k miles
So far the only mod is a Diamond Eye 4” stainless exhaust
Philosophy of use:
Truck is to be a safe and reliable daily driver.  Truck will also be used to tow a small camper short and long distances.  Reliability, fuel economy, and towing capability with low EGT’s are more important than a large dyno number.
Goal:
Reliable 24v in the 400-500hp range (Number is less important than a good running truck).
Removal of the VP44 for a more reliable system. (non negotiable)
Possible recipe:
Fuel Boss lift pump
VE Fuel Pump w/ dynamic timing
Unknown Injector (TBD)
BHAF
HE351VE with Arduino (open to other turbo recommendations but like the idea of a fast spooling VNT that can perform on the top end as well)
Questions:
Does the VE swap require a cam gear and timing case like the PPump?  Or is it just the VE gear and 1st gen cover?  (Basically a pump swap)
I have yet to see this swap on an 01-02 truck.  Are there any issues that I will see with this truck as opposed to older trucks?  I read something about crank sensors?h
Will the 1st gen cover simply bolt onto the 01-02 trucks?  No issues with harmonic balancer?
What are the differences in VE pumps?  I see recommendations are all over the place.  Intercooled? Non intercooled? 12mm? 14mm? Lift pump pressures?  What is right for my truck? Why?
Will the HE351VE w/ Arduino supply enough air for the low EGT/safe power I’m looking to make?
What injector should I run with that turbo/fuel pump?  What pop pressure should I run now that I’ll be running a VE pump instead of a VP?  Why?
THANKS!
  • Replies 81
  • Views 40.3k
  • syndicateshop
    syndicateshop
    I've messed extensively with a VE 24V and the BEST the BEST I ever got hand calculated was 28mpg.........
  • A healthly VP44 is going to be more dynamic in use than a VE.     the VE has variable timing, but it is advance as rpms increase.  IE at 1200 rpm you get ~15* of timing but at 2500 rpm you get 22* of
  • I look forward to your results.  PLEASE PLEASE PLEASE document your progress with it.  Videos etc  I am very curious to see the gains that could be had by using UDC vs the quadzilla.   Snap
1 hour ago, Me78569 said:
DDP's are known to be smokey.
you are also using tuning that is %100 above oem duration.  the quadzilla allowed me to pull duration down to offset the large injectors.
I'll give you a call when I am ready for the Quad and update my injectors.  Thank you for all the info.  Have a good weekend and Diesel Drags in Pueblo.
