- Replies 8
- Views 6.7k
Timburrr 4 posts
IBMobile 3 posts
Mopar1973Man 1 post
Today I went to borrow my friends car hauler to rescue my broken down commuter car and only the brake lights and turn signals would work on the trailer. I tried my second 7 pin connector for the 5th wheel in the box and it was the same thing, so I figured the problem is upstream of the 7pin connectors. Did a bit of reading and found the big square 40a fuse in the fuse box in the engine bay and sure enough she was toast. Stole the 40a from the fuel heater until the parts store opens in the morning and everything was working again.
I'm looking for some suggestions why this could have happened? I My guess is that it was one of the following things:
1) 19 year old truck and maybe just time for it to go?
2) My 3 year old son likes playing with water guns and could have squirted a bunch of water in the 7 pin connector and shorted something.
3) I have LED reverse lights on my dump trailer and maybe I was in reverse long enough for it to cook the fuse
4) maybe somewhere there is a corroded wire that is creating a lot of resistance
If the fuse pops again, where should I look first?
After replacing the fuse I drove around with my friends trailer and it was fine. When I got home I hooked up to my dump trailer since I will be working tomorrow and everything worked fine with the new fuse, so I don't think there is a short somewhere since the fuse didn't pop. The only relevant information I can think of is I recently replaced the battery on the dump trailer with a larger capacity deep cycle battery, but I don't see how that would matter. I've had the LED reverse lights on the trailer since I rewired it 1.5 years ago. I don't remember the numbers on them but they aren't a high power light. Maybe if I blow a fuse again I can run a relay with the main power source coming from the dump trailer battery instead of powering straight from the trailer wiring? Any advice would be greatly appreciated! Thanks!
Edited by Timburrr
grammar
