Looking for help on a daily drive tune
I’ve just got the truck running and still have the edge comp box installed and it is a smoky mess so I’m looking to get a daily tune that I can work off of. The mods to the truck are a 6.7 188/220cam 6x.018 injectors dragon flow pump and sxe480 and a sxe364.5
  • Replies 11
  • Views 2.4k
Use some of the tunes in the tune repository.  There aren't any tunes for that size injectors, but there are tunes for big injectors that you can work off of.
@Me78569 @Quadzilla Powerso I've got a couple questions, First can you lower boost level fueling any more there 50%? and second question is once i set my daily tune anything under 10% throttle the truck will lope, once pass 10% it runs fine and it will idle fine this is only on lvls 2 and up lvl 1 it is fine
Edited by blkruby
no lower than %50 as loping becomes a real issue as the ecm and the quad fight for control and hte ecm will go into freakout mode.
ok, so what would cause the loping i have now under 10% throttle
Same thing,  the ecm see's rpms slightly drop as the quad alters fueling to bring it down.  the ecm then add's fuel to make up for it and the fight continues.
this is normally limited to sub 1000 rpm area.
so is there and thing i can do in the tune to alleviate this? also is there and thing i can do in the tune to help with smoke other than the boost level fueling
not really the ecm prevents us from doing much about it until rpms are up enough to keep the ecm from sending high priority messages.
If you are already at %50 as a starting point you are pulling as much fuel as possible.  you can pull timing to try and help smoke, but I have not seen great results.
you may have reached the limit of the mechanical injectors vs hole size and the ablity to inject fuel at low pressure.  how big are your injectors?
Edited by Me78569
6x.018 and a dragon flow pump and the injector are set a 260 bar
260 bar are going to make it EXTREMELY difficult to control smoke on that size injector.  you can try pulling a ton of timing, but I think you are at the limits of what your mechanical setup can do.
Going from 350bar to 305 bar with my old 7 x .012's was like going from stock injectors to 7 x .010 injectors in terms of smoke increase.
I also noticed significantly worse idle and off idle states with 305 bar vs 330 bar.  that is only my testing and we dont have enough data to say for sure.
Edited by Me78569
i think the reasoning for low pop pressure is for timing on the dragon flow pump at the higher pop it could hydro lock the pump. but the truck idles great and climbs threw the rpm smoothly
Dunno really what the reason for it was, the builder would have to answer that question.  My guess is it is related to power output as lower pop = more fuel for a given duration.
You can try running around on lvl 1 as there is no low limit for valet mode.  Set it at %20 does it still smoke?
Guessing your setup is going to mechanically limit your smoke control though.
