Quadzilla Adrenaline
- Replies 23
- Views 10.1k
adamey1000 9 posts
Mopar1973Man 7 posts
Me78569 4 posts
trreed 2 posts
Yes. iQuad is WiFi and iQuadBT is BlueTooth. I'm using a LG G5 phone (android). https://mopar1973man.com/topic/12976-getting-the-most-from-a-lg-g5-cellphone/ Beyond that no,
The only reason I suggest people use android is cost to replace, an android device can be found for 1/10 that of a IOS device. If you run like Moparman says then that doesn't matter.
what no impact driver install?
I think it is time for me to make the jump to a more capable tuning box. I have decided that the Adrenaline is the way to go, mostly from lurking and reading all the great information on this forum. I have a few questions.
Is there any difference in the iQuad and the iQuadbt? I know one is for iPhone and the other for android, but is there any other difference? My phone is an iPhone, but would it be beneficial to get an android device to keep in the truck?
I have never used a wire tap box. Is the stealth plate a good purchase? I want to do the wire tap once and know it’s done right.
Since I am running on the stock turbo, I have blocked the WG off to let the turbo build boost. With the smarty and injectors, I have been building 34lbs max. I assume with the extra fuel that I will need to get an adjustable boost elbow to keep from over driving the turbo. Is there one that you guys prefer over another? I would like to set it around 32lbs or so for now until I head studs and get a bigger turbo.
Will the Adrenaline come with all of the probes or sensors that it requires? I have a full set of mechanical gauges that I would like to keep. Will the Adrenaline still be able to monitor everything it needs to do it’s job? Installing a second egt probe is not big deal, but if it can piggyback on the existing, that would be great.
I would appreciate a quote quote on all of the things above as well.
