New developments on turbo diagnosis and a surprise!
- Replies 19
- Views 7.5k
woodtrucker 9 posts
Me78569 7 posts
Mopar1973Man 1 post
Popular Days
i've seen brand new turbos need to be calibrated. I have a friend with a diesel shop has to use his snap on tool all the time for new 6.7 turbo installs. the calibrate tool can't enable/disab
Either should work, the difference is normally just what pin you talk through. I'ved use 4 or 5 different boards and they all work once you get the right pin.
I got a surprise call from the PO of my 07 mega cab tonite and boy was it a surprise!
He gives me the history on my truck and wow, it answered all my questions about a 6.7 and I've solved the EB not working mystery!
He says:
-It's got a category 5 suncoast rebuilt transmission. Said he hauled a heavy load on original trans and messed something up and immediately had the category 5 rebuilt transmission put in with a package deal they were doing at the time with H&S tuner. He said it was good to either 500 or 700hp. I think 500. Claims this was an $8k tranny that he was really bummed about just letting go with the truck. He wanted to replace it with a stock one but just decided he didn't want to go through with all that and told I had a really great truck that should last a long time.
-He also said it was deleted in 2011. Not sure of mileage at that time. probably around 100k. Has 160k on it now and new turbo since it's been deleted and ccv reroute so turbo has never seen any junk.
-He also said the reason exhaust brake wasn't working was that he had the turbo replaced and it needs dealer to set it up. I'm assuming that means it either needs to be calibrated or enabled in pcm? or both? So will a dealer be able to understand exactly how to do this? It definitely explains why turbo seems to spool correctly but exhaust brake doesn't work.
Should I return truck to stock before the reflash to enable exhaust brake if that is the problem? Or Should I just ask them to calibrate and see if that gets it online?
Thanks guys and for the record I trust answers on this forum more than anyone so thanks for being so good at cummins diesels y'all!
