If there's already a thread could someone link me it? My gearbox on my 99 is leaking pretty badly, like from full it'll leak out in a day, and instead of just resealing the gearbox can I just install a 4th gen steering box? I remember someone I follow on Instagram putting one on his 2nd gen (I don't know the year) but I didn't know if it was possible on a 99 since it isn't the newer front end. Anything helps. Thanks!
  • Replies 4
  • Views 4k
3 minutes ago, Mopar1973Man said:
Got to change the hydro boost and power steering pump neither are rated for ATF. It will ruin the seals. 4th gen is ATF system ours is a power steering fluid.
So probably just get a reseal kit? I never got a link to that one you mentioned
Just now, Mopar1973Man said:
Bluetop is vendor on the site you might hop over to his forum and get his phone number and order a kit.
Gotcha, thanks man
