Retrofitted led headlight wiring problem
- Replies 11
- Views 2.9k
Me78569 5 posts
zach199917 5 posts
Dieselfuture 1 post
So I got the retrofit led headlights from the hid factory with the morimoto led. I put them in and nothing worked they said move the pins around in the 3 prong plug that plugs into the stock headlight plug in so I did and I got the low beams to work now and the high beams with no problems. But now I cant get the lights to shut off with the switch any ideas on what to try now. The only way I can get the lights to shut off is pull the fuse from the fuse box under the hood but they still flicker very faintly. The hid factory said that I'm on my own and they have never heard of the problem. Thanks
Edited by zach199917
