Looking for how-to on the PCM ground...
- Replies 3
- Views 11.2k
Mopar1973Man 1 post
IBMobile 1 post
rotohead 1 post
Just cleaning up my rewire job of W-T's genius redo and now I can't find the info on the way to redo the passenger side PCM ground wire coming out of the harness below the PCM going to the passenger side negative battery. It's the one with another of those suspect grey plugs and it use to splice into the cable that included the poor design ground wire coming in from of the engine and over the top of the alt from the 4 wire splice of PCM/ECU/VP44/PDC. What was his recommendation on fixing that other PCM ground? I've looked everywhere and can't find it now. Thanks. I'll be so glad when this is all done.
