center cap help!!!
I changed my wheels on my 02 from steel to alloy,Posted Image the center caps from the steel wheel didn't fit!,I got on ebay a new set of caps that were supposed to fit.
THEY DONT fit the lug nuts!!! if anyone of you guys run the same wheels please let me know which cap you used. thanks.
  • Replies 10
  • Views 3.1k
the diff is the lug nuts i think the alloy wheels have a large shank that the metal tangs on the hubcap fit too
I think Koyote is right... The lugnut is the answer to the mess... Alloy rim use a fairly large lugnut compared to the steel rims...
mopar do you have any pics of the lugnuts?...my truck came with Posted Image
On my wheels, just like you have pictured, they are 24mm, Sorry no pix.
The center of the lugnut is hollow looking. If that makes any sence:2cents:.
hope this helps.
---------- Post added at 05:12 PM ---------- Previous post was at 04:57 PM ----------
just mesured with lugnuts on wheel, It was at 7/8'',,, from seated on the rim to the top of the nut, If you need anymore info I can take one off.
I'm thinking as mike said, they are diff.
dodge and chevy's bolt pattern is 8x165.1 and stud size 9/16-RH. the new fords(98+) is 8x170 and 14x1.5 and i think the bigger fords(450sand 550s) us 8x200mm
they have different lug nuts at oreilly's, but they come in 4 packs @ ~$9
[ATTACH]1404[/ATTACH]ok, so i mesured my lugnuts and they are 7/8 from the wheel to the top of the nut...and they are also 7/8 wide... looks like mopar's luguts!!!
mopar man what is the serial number inside your center cap?... it is 2124?
