Lock up switch now high idle.
So I decided to finally instal a lock up switch, and it works fantastic.  But now, if high idle is turned on on the Quad, it turns on no matter what the outside or coolant temp is.  I have to disable my turbo timer or it comes on.  It stays on past the 120 degree warm up setting on start up as well.  It never did this before so my question is what the heck happened?  Is it because of the jumper in the trans relay?  Please help me understand lol.
  • Replies 4
  • Views 1.5k
Are you on level 0? Is your warm up mode set too high? Basically warm up mode hold level 0 till warm up is complete once it completed the the set level is restored. So if the module was unhooked it would revert back to level 0.
:doh: I’m an idiot.  Never turned the level back up to 3.  Haven’t changed a power level in a long time and it slipped my mind.  Thanks guys, sorry for wasting your time.
There is no such thing a dumb question. We are glad to help you out. Not a problem and no it wasn't a waste of time I'm sure someone else will forget too. Be thankful it was an easy fix.
