- Replies 37
- Views 9.4k
Mopar1973Man 12 posts
Toughspot 9 posts
Bullet 6 posts
dripley 2 posts
Popular Days
Much more affordable and fulfilling to do it all yourself if you can. You got plenty of support from here. If I would have paid labor to do everything I've done to my truck I could have b
Best part you know its done right!
Yeah, that was me... What he said is true. I heated the ball joint knuckle to help expand the metal. We started with a propane torch but no luck. Then fired up the acetylene torch and hea
Hey guys,
I just replaced my front suspension coils with a 2" level kit including shocks with Thuren Fabrication brand parts, and I also replaced the stock track-bar with a Synergy adjustable. Everything was installed per manufacturer's recommendations. My truck still makes a noise when I hit a bump and it's annoying. I have 35x12.50R20LT tires, though I doubt thats what's making or causing the noise. I'm not sure if its the ball joints or not. But in you guys experience, what all components would contribute to a hard ride and a "knock" like sound when hitting a bump in the road. I have the same issue on the rear, but those shocks haven't been changed as yet. I only have the stock leaf spring and shocks on the rear. I will change the shocks once I narrow down what the problem is on the front suspension.
