Grounds and electrical stuff.
I think I've got some electrical issues. My main problem is the apps. It probably needs to be replaced..but I'm trying to properly diagnose it, or if it's something bigger.
Back story. The truck at all speeds has what I think is "dead pedal". 47re. When I'm taking off, the truck seems to go, then cut, then go..like it's not certain where the pedal is, even though I haven't moved my foot.
The biggest problem for me is highway driving. I can't maintain speed with cruise control. If I reset the apps by unplug, key on reset, it'll work for a while, then fall off. If I set cruise control, at say, 65mph..rather than keeping a steady engine load of say, 20%, to maintain 65 on flat road..it will shoot you to 30% for a second, then drop to 0, then jump up to 25, then zero, etc..it's like it can't properly use or calculate what the appropriate engine load needs to be.
I've tried cleaning grounds: pcm strap, passenger body, I've deleted and hard wired passenger battery ground disconnect, I've installed a bd noise isolator, mounted to that clean passenger side body ground.
So ohm testing. I'm no electrician, but here's what I've found. I have a digital mm, on screen it sets m infinity symbol..I guess that is milliohms? (Is that even a thing)..when the truck is off, putting neg on pass battery neg, pos to alternator case, I get 0. However, on the body grounds, firewall pcm strap, and body ground with bd iso, I get 0.03.
With the truck running..alternator case / block, it's still 0. However, body grounds and firewall ground to pcm go up to..0.16. Is this within spec, and what could cause such huge increase?
I have a nation's alternator, because my old one was leaking ac noise..this one however, is not. My black / tan is routed out to radiator, then around to battery. It is not wrapped in tin foil.
I had my battery terminals replaced with military terms. (I asked for new cables too, but they retermed old..). Anyway, I've noticed some battery spill on both batteries. Passenger side new pos term has a tiny bit of corrosion, but the term itself has turned dark gray. I never had any corrosion on my old terms..and I did notice my voltage, temporarily in the morning, was higher than usual..not grid heater fluctuating, but constant. I felt the battery cables when I got home that day, they weren't warm at that time..but I feel like I've got some intermittent electrical issues I don't know how to identify properly.
Oh, and my radio stopped working completely. It started off occasionally, then it would randomly turn back on once n a while..now it never turns on. It has power, lights, hitting volume turns clock on for a few seconds, then turns off again.
My blinkers, both sides, randomly stick on. I think that has to do with gauge installation tho..probably unrelated.
Jesus, sorry for long winded post..I hope someone can skim and help lol.
Batteries are from 2015..had them load tested at an interstate battery store..said they were fine
  • Replies 85
  • Views 17.9k
  • I just posted, but I see that Dripley beat me.  He went into more depth and provided more information than I did.   Are you using an electric soldering gun? What is the wattage?  The joint i
  • Statistical probability ends with me. If it can happen it will happen to me from my experience. Or close to that. For real.   Edit: I'm a paraplegic in a wheel chair from a less then 2 % cha
  • I am pretty electrically challenged myself, but WT's ground mod is pretty simple and @Mopar1973Man explanation is in a little more laymans terms. I mostly understood it, but if you just open the harne
17 minutes ago, dripley said:
How common is a catastrophic short to ground and an under hod fire?
Edit: I'm a paraplegic in a wheel chair from a less then 2 % chance something would fail. No regrets but many lessons learned.
Edited by rotohead
Picked up a Mopar branded Group 34 battery a few days back to replace the missus' 5yr old battery on her winter beater, as one cell was flaky, and desulfating the battery didn't help.
Pleasantly surprised; static voltage was 12.75v on the dealership counter, & it was cheaper than the WalMart/Costco equivalent.
The OEM 15yr old Denso alternator charged at approx 14.2v with all vehicle accessories on, showed an AC ripple of .035v at the battery (.033v at the alternator posts), so I took it out on a 30 minute highway drive.
State of charge the next morning was 12.95v
IMG_0611.jpeg.3d90032387533a77b8ea427260aa9705.jpegIMG_0608.jpeg.f0d281f1de426b6b092ce10d3cc66a22.jpegIMG_0607.jpeg.c9b265adb9822aebed30dd84ca3f1563.jpegIMG_0606.jpeg.59f802f0b1d15b37be33ab8dca29ead9.jpeg
Only seen it a couple times;  both on Jeeps that have been "modded with all the latest accessories" - winch, dual batteries, one wire alternators & some real questionable internet inspired power cabling.
My buddy's 93 W250 fell victim to it too; previous owner replaced the fusible link with a piece of spliced in straight 6ga, the very tired alternator's positive diodes shorted to ground, and the resulting under hood fire took out all AC wiring, the serp belt, the AC hoses, and part of the plastic fan shroud.
Fixed all the above stuff & did his KDP/case bolts/freeze plugs early this morning, just waiting on new AC hoses before I button it all up & weld up a front receiver so he can put a quick detach plastic blade on it to plow his driveway.
I found this interesting. I purchased a battery cable kit from Geno's garage back this summer and just started installing it a couple weeks ago. Never did look at the install instructions until the other day and noticed the 'optional' battery cable. This was not in the kit from Geno's but it shows me this mod has been known  to others for awhile and it is proper to have some kind of protection/link in the system. I already have a fuse and holder purchased that I'm going to use otherwise I'd call this guy and get the optional cable, or at least inquire about it. BTW, the kit is very well made and might be a little pricey but I feel is worth the cost.
Just wanted to mention that while doing this mod on my own truck I was having issues with the lights inside and outside dimming intermittently.. low and behold the auxiliary neg cable going to the block was more than half rotten inside the black wrap.. if the wrap wants to come of super easy it’s more than likely corroded on the inside my instincts told me to rip it off and look inside but my pocket book was saying no that’s 1guage copper but it really isn’t bad to replace
