Looking for mid size injector race tune
I have 100hp injectors and on 35s. I have found a lot of tunes on here but not a mid size injector race tune. 1999 2500 5 speed swap with 7x.009
  • Replies 7
  • Views 1.5k
I've got to ask what is axle gear ratio?
I believe 3.55. I just downloaded the other mid injector tunes that I could find on here. What parts of those tunes will I also have to touch to modify them for my gear ratio, tires, elevation etc.?
Okay. Well in a race tune, what is a rough idea of what you want it to do? Is there a good base map I can use to edit that will get me a bit closer than starting from scratch?
The tunes for mild injectors are base maps.
Add fuel according to your needs as the tune articles go through.
The tuning article has a how to.
