- Replies 6
- Views 1.7k
dripley 3 posts
Dieselfuture 3 posts
Popular Days
Make sure you check your Sometimes you can get it free at But seriously it's probably your flasher. There is original one that will let you know if the bulb is burned out, or i
Some beach!! Learn something new every day.
Works best if you use vacuum pump first
For some reason when i use my blinkers if i leave them on at a stop light they will blink like they are supposed to then they will stick or stay on and stop blinking. I thought maybe a bad bull so i replaced them all and still having the same issue. My dad mentioned possibly the blinker switch on the steering column but i didn't want to tear into incase anybody else has had a similar issue with an easy fix.
