Anybody running diesel power sources Twin/ Compound turbo set up?i just ordered the set and was curious if the install is as simple as they say
  • Replies 5
  • Views 1.4k
Compound install on my truck took about a day, but I was also painting the pipe and getting pulled away to do other things.  It's a pretty simple installation.  Leave everything loose until it's all together is my advice.
@trreed what size injectors are you running? I'm assuming your truck is your daily. Im wondering if i should get bigger injectors as I have 125s right now
I would at least step up to 7 x .010's depending on power goals.  A nice set of 7 x .011's would still be easyish to tune and provide ~600 hp worth of fuel
for a DD truck I think 7 x .010's are the right choice provided you are happy at ~525-550 hp
would i have to upgrade injection pumps to run 7x011s?
Nope, they work until they don't regardless of injectors
