Posted December 26, 20186 yr Anybody running diesel power sources Twin/ Compound turbo set up?i just ordered the set and was curious if the install is as simple as they say
December 26, 20186 yr Compound install on my truck took about a day, but I was also painting the pipe and getting pulled away to do other things. It's a pretty simple installation. Leave everything loose until it's all together is my advice.
December 29, 20186 yr Author @trreed what size injectors are you running? I'm assuming your truck is your daily. Im wondering if i should get bigger injectors as I have 125s right now
December 29, 20186 yr I would at least step up to 7 x .010's depending on power goals. A nice set of 7 x .011's would still be easyish to tune and provide ~600 hp worth of fuel for a DD truck I think 7 x .010's are the right choice provided you are happy at ~525-550 hp
