- Replies 4
- Views 2.2k
Ed ke6bnl 1 post
Huskiemuskie 1 post
Marcus2000monster 1 post
Rotax3006 1 post
Popular Days
Check the wiring going through the door post/frame area by the door hinges. I had one break the wire in there. It would work if you wiggled it. I would think you could pop the switch out and check f
Sounds like the switch is worn out. The contacts are likely cracked/broken. Try swapping passenger side switch over to driver side to berify that the driver switch is failed.
I have had good luck with a contact cleaner spray like Deoxit D5 not cheap but I refer to it as magic electrical spray
All of the driver side switches work e.g. locks, passenger, driver auto down/manual down. however when you select drivers side window up... it goes up about halfway and stops... you have to wait for a good amount of time approx. 15-30 mins it will go up some more then stop and you have to do that process until it all the way up.... any ideas?
