- Replies 13
- Views 13.8k
Me78569 4 posts
BlkCummins01 4 posts
Bullet 3 posts
trreed 2 posts
Popular Days
People define drivable differently. I wouldn't consider that setup drivable for my needs. I would suggest a 62 over 75 setup. It is well tested and works well on a vp truck for 60
An hx55 is doable but it would spool like a pig and be smoky. I think it's somewhere around 70-71mm. Some drivability will surely be lost and egt's will be warmer. Not to mention unhealthy drive pr
My current compound setup is the full DPS twin kit 62/75 and it came with all the piping that was pre-engineered to fit perfectly...and it all does with the exception of the heat exchanger on the auto
Hi all. I am currently in the process of upgrading from the supposedly unsafe and shaft snapping hx40 to a larger charger. It is currently set at 45psi and I’m making somewhere in the 420-470hp range. I want to be around 600+. I have found a guy with a bunch of turbos that is going to build one for me to whatever specs I desire. So I am trying to figure out the single best turbo specs for my exact modifications to get me around that hp mark and still be somewhat driveable. All my previous mods should be listed below. Thanks for your responses.
