Wire tap to body ground on APPS wire
- Replies 10
- Views 10.1k
Mopar1973Man 5 posts
FosterW 3 posts
IBMobile 2 posts
Popular Days
Remove that ground return to stock. Then test your alternator for excessive AC noise. Double check for noise filter on the PCM and remove. Then do the W-T ground wire mod.
In the C1 connector on my PCM, the orange/black tracer wire that leads to the TPS has a wire tap connected to it leading to body ground. It is tapped a few inches out from the PCM. I am having no issues at this time, just curious if anyone knows what this is all about. It does not appear factory, and wiring diagram does not show that wire going to ground for any reason.
02 automatic.
