Trailer Wiring install '71 F250 Fummins
- Replies 23
- Views 6.1k
IBMobile 10 posts
Bacon Creek Metal 10 posts
Mopar1973Man 3 posts
I'm book with work right now but I'll have lots of time next week to put something together.
In the PDC there should be a 40 Amp fuse separating the truck from the trailer. Fuse #8 - 40 Amp As you will see the power lead for the brakes come from there, and power for t
@Mopar1973Man this is for a 1971 Ford F250 with a Cummins engine.
I want to install a Goose neck plug in the back of my '71 F250. I want to do it through a separate relay/fuse box. I have been searching for almost a year for a write up on it or a kit or...….
So I thought I would ask here. How do I go about this. I want to have the electrical load separate from the main wiring to protect the main pickup harness. I have a 20' chunk of trailer harness and the plugs, a relay/fuse box out of the '94 dodge donor, and a brake controller.
I also want to put the headlights on relays and have a relay for additional lights.
Any guidance will be helpful.
