LED lighting - Exterior lighting
Now I've gone to the exterior lighting.
The left bulb is a switchback bulb for the front marker / turn signal. It's a white light on parking lamps but amber on the turn signal. Then the bulb on the right is a standard red tail light blub. Both sets are above normal lumens.
Front amber
https://www.superbrightleds.com/moreinfo/tail-brake-turn/3157-switchback-led-bulb-dual-function-60-smd-led-tower-a-type-wedge-retrofit-car/1916/4478/
Rear red
https://www.superbrightleds.com/moreinfo/tail-brake-turn/3156-3157-ck-led-bulb-dual-function-27-smd-led-tower-wedge-retrofit/3557/7523/
  • Replies 29
  • Views 5.9k
    NAPA heavy duty flasher. That's it.
    Napa Number - EP-27L   https://www.napaonline.com/en/p/NF_EP27L   Full article here with all the info in one spot.
  • I swapped out all of my interior and exterior lights on the Ram to LEDs including projectors, high beams, dash, climate, cab, fender, etc.  I bought new headlight and taillight assemblies since the he
14 hours ago, Mopar1973Man said:
You're stuck. There is no LED bulb capable of being used in a factory reflector period.
O.K.  So for the Factory headlights what is the best bulb?  In a bright white?
Thanks
Michael
Edited by int3man
4 minutes ago, int3man said:
O.K.  So for the Factory head lights what is the best bulb?  In a bright white?
1
SilverStars are about the best in a halogen.
Then there are the big ones 100/80w blubs...
https://www.amazon.com/HELLA-100-80WTB-Wattage-100-9004/dp/B078SJ19DK/ref=sr_1_1_sspa?keywords=100%2F80w+9004&qid=1551842762&s=automotive&sr=1-1-spons&psc=1
  • 3 weeks later...
Hi Mike,
               Just a Quick Question.  I walked past my truck Monday morning at 3:30 A.M.  and  I noticed that the left  reverse light was on and the truck had been parked for 2 days. When I was shifting the truck on the weekend I noticed that it sounded different.  I was in 4 wheel drive.  So my question is how is the reverse lights controlled?  An adjustable switch?  Or is my linkage have a loose bushing?
Thanks
Michael
On ‎3‎/‎27‎/‎2019 at 7:40 AM, Mopar1973Man said:
Auto is a switch near the pan.
Man the reverse switch is near the shift tower.
Thanks have you done a REverse light bulb in L.E.D. ?  I have one that is lit bright with 2 L.E.D.s and another with 20 L.E.D.'s that i can see are barely on.
Thanks
Michael
Edited by int3man
Naw... Not as good as my 100w watt bulbs on the axle. I will upgrade them but I'm going to add floodlights in LED to the axle. Much better than the stock back up lights that doesn't work really.
Another stupid question  I just looked and my 2001 has a 3 wire switch, most of the parts houses show a 2 wire.
Is there a manual that shows the difference between the Neutral Safety switch and the Back up light?
So I see a difference of a Vin 6 or a Vin 7?  My Vin is G7 is that what they are talking about?
Michael
Edited by int3man
1 minute ago, Mopar1973Man said:
Backup Lighting wiring map 1999 Dodge Ram
Yup 3 wire.  I'll call Oriley's Auto Parts!
