Does the head end of fuel injector line have some type of Teflon grommet or is a metal to metal contact.
Could I clean up the cross over tubes and replace the o-rings and re-use them. I cleaned up cross over tube for #1 cylinder. It is pitted.
7FC436B5-3384-40B9-B171-453472513EEB.jpeg.3aaf819dfaf446c809e2fb448b1b6fdb (1).jpeg
  • Replies 3
  • Views 1.4k
  • I started with 400 grit sandpaper. may just start with scotch, then some bourbon and go to town on them with a scotch brite pad.
All metal to metal contact surfaces. I always clean mine up with a scotch brite when I have them off. Still using all the oe tubes and lines except for #5 line which broke about a year ago.
  • 3 weeks later...
Id just clean the carbon stuff off, check the orings and put them back in.
