- Replies 7
- Views 2.2k
Unreal Summit 4 posts
dave110 2 posts
IBMobile 1 post
Popular Days
Sudden white smoke to me would seem like a fuel timing issue ie. seized timing piston in the pump. But that should have thrown a 216 code I would think,
With no code you're going to have to do some diagnostics. This will help determine if it's the VP44 or not. https://www.bluechipdiesel.com/runningtests
Fixed it! Relay for the retrofitted fuel pump in tank was bad. Whoooo hooo
I been driving my brothers 99 truck for work. Started it up today and let it run for just a minute while I got situated in the truck. Then it just cut off like it ran out of fuel. White smoke from the tail pipe. I tried to start it backup. White smoke no start. Now no smoke and no start at all where should I start?
Edited by Unreal Summit
