Quadzilla problems, need some direction.
No boost and 100% transmission slip????
So I just changed my oil and fuel filters along with fixing an oil leak on the vacuum pump.
To fixing the oil leak I unplugged the sensor behind the vacuum pump and the three wire plug next to the engine ID plate..... fixed the oil leak and re-assembled everything.
While I was drive home, I noticed it not registering boost and the trans was at 100% slip.
I foot braked it to try and build some boost. It start to build up but felt like it just fell on its face and didn't have any power.
Still drove okay
I tried resetting the app sensor no change.
01 2nd gen, BT iquad all the normal mods.
Looking for ideas?!
  • Replies 4
  • Views 2.4k
sounds like either you busted a wire to the map sensor or the map sensor died.
Trans slip is based on your vehicle setup in the app.
any codes now?
No engine light. I haven't checked to see it there is a code.
I'll try and check them off the instrument cluster.
I think I have quadzilla problems now I've lost more sensors
Check the data link plug.  Both the map sensor and datalink plugs are right in the area you were messing with.
Well (Me78569) you were right found a broken wire on the truck harness side of the data plug.
Wont let me attach a picture for some reason.
Edited by 01dodge24v5.9
More info
