V2 Staging Flash - App Problem
Hello @Quadzilla Power,
I would like to try the staging flash file for controlled boosted launches (low boost). The problem is, the app limits the Boost Defuel option to minimum 23 PSI. That's way high for my intentions. I would like to set this to around 10 psi. Can this limit be lowered?
Thank you,
-Kole
  • Replies 5
  • Views 3.5k
Personally, I think this deserves it's own permanent parameter, like "Max Boost @ 0 Speed". I look forward to being able to use this in the future. Even in the download link, it mentions an example where the driver would like to leave the line at 10 psi. But this is not currently possible.
This change would be handled in the Json vehicle profile.  I can't remember how I got around this in my testing.
The staging flash was a beta / test thing.
It could have been.
The flash doesnt support a specific tuning variable to work, it is a simple reuse of the boost limit variable.
I should prob delete that flash as i dont think things are in place to use it anymore.
