Injector lines removal / engine lift bracket
I'm having trouble removing the back 3 injector lines. Not from the head but the brackets holding them down on the deck.
Do I need to remove the engine lift bracket to do this, because those bolts wont budge.
Where exactly are these bolts located that hold down these lines?
Thanks
  • Replies 5
  • Views 1.3k
They are on top of the intake cover for the most part. There also some brackets that hold 2 sets of 3 going to the VP. Clamps with blu blocks. These are all very obvious unless I am missing something.
I've removed all of the bolts on the intake cover that i could see that hold down the lines. Are there bolts behind the engine hoist that I wouldnt see unless I could take it off?
I got the engine lift bracket off but these back lines still aren't budging. I might just start taking the lines off individually even though it'll be a pain to put back together.
They are not that difficult to put back on. They pretty much can only go on one way. I had take those same 3 off individually when changed my head gasket.
Whats the reason for removal?
Dont loose any of the blocks or clamps. I had to replace some. The screws, metal clamps and the blue blocks were 7 or 8 bucks apiece from Cummins.
Edited by dripley
