- Replies 3
- Views 968
Tractorman 1 post
keithb7 1 post
hdpwipmonkey 1 post
I recently performed my first rotor swap on my 98.5 2500. I pounded out the wheel studs with a single hit of a 5lb sledge. Easily came out. I swapped the wheel bearing assy over to the new rotors. Used same sledge to set the studs back in the same wheel bearing housing. A few studs did not want to set back in place flush. I whacked ‘em a few times and carried on. Thinking I’d pull ‘em right thru when I torqued the lug nuts up at wheel installation.
Well I’m still cranking a few nuts tight. I’ve been test driving and get a slight vibration when braking. I have driven, braked and got hubs warm, then retorqued 3X. Seems I am almost there as the vibration is improving with each retorque.
What is the correct procedure? A hydraulic press I assume? To seat the wheel studs in the bearing hub properly, the first time?
I’m goin back in as I decided to order up new front wheel bearings. Mine appeared original. I ordered new NGK USA built bearings. Came with new studs too. I’d like to seat them right this time.
Also I read 175 ft lbs on the centre nut for bearing pre-load. Plus a little more to align the cotter pin. Seems high but I have limited experience with the truck. I’m used to 3-4 ft lbs on other light vehicles I’ve owned. This Torque is right? Just double checking. I appreciate your experience Thx.
Edited by keithb7
