Quadzilla adrenaline v2
Have a new quadzilla Adrenaline v2 iQuad. Wired up correctly. I select vehicle. It say connect to internet at the bottom. Well it is. I turn cellular data of the app tells me. Only thing that works is speedometer and power level buttons. Any help would be appreciated. Thought I’d ask be before sitting on hold tomorrow
  • Replies 3
  • Views 2.3k
sounds like it can't find the vehicle profile.
Have you tried opening the app while on wifi, but not connected to the unit under the hood?
Not sure I understand your question. I’m using my iPhone to connect to the iquad module. I select my vehicle 99 Cummins. Nothing ever loads. Says enable internet connection. Cellauar dat is is enable for the iquad app. Sped and power levels only things that work
take the phone out of the truck to someplace where it can't connect to the box under the hood.  open the app and then select the vehicle again.
