Quad adrenaline and heat
Does the quad adrenaline have issue hooking up to the app or working correctly in hot weather.
Its probably 95* and my tablet hasn’t been able to connect today and had a failed status bar earlier.  Truck also felt like it had a couple of issues and then I told the app to run the default and it seems to have gotten better.   Still have not been able to connect and do anything though.
Ambient temp recently is high 90s (being from the nw that is hotter then hades).
  • Replies 5
  • Views 1.8k
Shouldnt matter as long as the tablet isnt overheating and turning off Bluetooth.
Cheap tablet and it’s all quick trips.  So very potential.
try keeping the tablet in the shade, load your tune when you start the truck then run without the gauges for a bit.
If the issue does away then the tablet is likely overheating and turning off bluetooth.  you could have all sorts of weird issues.
Yeah went for a drive got the inside of the truck cooled down and then turned the tablet on. Got everything fixed.  So probably heat and the tablet.
you can try mounting in a different spot.  on the dash under the glass will reach temps of 160*f+
