finding wire connection location need some help
OK guys I had A guy  put on new fenders and repaint my 01 well all the wires did not get put back on and or connected having trouble on location of a couple wires go can someone post a pic or give me a location where these wires go thanks in advance this is on the drivers side of truck
  • Replies 4
  • Views 1.8k
  • Those are grounds, nothing special.  Clean them up, then take this nut off, clean some of the paint off the nut and fender and attach.
2028660817_20190808_194805.jpg.df0ae8cc3ed1adde1efff498dc7766e91.jpg.765404054a82279377fbde3fd407b7a5.jpg
OK thank you so very much sir I thought they were all grounds but was not sure where they got mounted or best place to mount them and as you can see they are missing a few bolts that mount the fender really aggravated how this came back to me
The larger one looks bad enough that it should be changed to a new ring terminal.  If one is like that it is likely more are going to need attention. :2cents:
yes for sure thank you I did actually did replace that with new ring terminal cause when I started cleaning it up things were getting worse so i changed it. yeah I know working on going over them and cleaning and or replacing them as i go been working on electrical now for a week thanks for the input this forum is such a great place.
