Hello new here need some help my truck was driving fine no issues at all I stopped shut truck off for about 20 min then went to start truck to leave and would not start had no fuel at the valve on injector pump so I swapped the lift pump and bled system and truck fired right up drove around for a couple hours parked and went to start truck and same thing no fuel pressure and would not start I did notice the after first replacement of the lift pump Tac was inop any help would be appreciated have limited tools as I’m out of state working thank you in advance
00 2500 5.9 4wd automatic 310000miles
  • Replies 2
  • Views 1.2k
You need to put a scanner on it and check for codes. Sounds like maybe either the crank or cam sensor is going south on you. I do not remeber whether your 2000 has both or just the cam sensor as my 02. If the ECM is not getting a signal it will not let the engine start. You need to scan it to see whats happening.
Thank you I was thinking possible crank sensor I have no access to scanner and can’t drive anywhere to get scanned maybe I’ll just grab one and install and hope for the best
