- Replies 23
- Views 3.8k
crav70 12 posts
Me78569 6 posts
dieselautopower 2 posts
kzimmer 2 posts
have you done a boost leak test? sounds like you have one or some sort of issue post changing the turbo and injectors. how does the quadzilla's default t
I want to point out final ratio plays a roll in EGT's. I see you only 33 inch tires but it will make the final ratio even longer legged. 3.55 will drop to about 3.30 roughly to the ground. This increa
I've been running the Daily tune from the tune repository here with a few adjustments but I'm not sure if ive helped or hurt the performance. I have also switched to a "Daily" tune that i wrote based off of the Daily tune in the repository. My issue seems to be I cannot get the turbo to light well and egts cruising 65-70 are 1000* or more. Cruising 65-70 I'm around 1800 rpms with 0-2psi of boost. If I roll into the throttle and try to pass or accelerate it will skyrocket to 1500*. But i have no real excess smoke as before and i can drive pretty smoke free on the max level, but when it does smoke it seems to have a greyish tint.
I haven't been happy with the truck since swapping from the RV275s and hx35 with an Edge. I wasn't crazy about the edge then but I at least had decent fuel mileage. Now my mileage is down to 12-13 city or highway it doesn't matter. I'm to the point of swapping to a he351cw or selling the truck. My question is where do I need to start with the tune to help lower egts?
Also attempting to upload the tune for everyone to see
iQuad-2019-09-26-09.51.19.json
