Tunes for a compound set up??
Hello folks, I browsed search bars and had some questions.  I see there are some pre built tunes for different combos. I am going to be installing 362/475 compounds and a set of 150hp injectors,  I see the different injector set ups but nothing to plentiful for a compound set up?
Any direction or input would be great!
  • Replies 4
  • Views 1.3k
injector size is the key info when it comes to the tune.  the extra air just means you can throw more fuel at it up top if you like.
Thanks for the info! So I essentially just need to match a tune to the fuel set up and away we go. Figure I'll use some of the base files on here as I'm not to keen on jumping into my own tuning until I have some time to read through some of the threads on here
grab any of the mid injector tunes then adjust from there.
You'll like this setup...same thing I run and it rips.  I hope that your tranny is ready cuz it will smoke anything stock.
