2007 5.9 guages going crazy! Help!
Just seeing if anyone else has had there cluster go nuts while driving. Oil, battery, fuel and temp guages dont move, they stay fine. The tach and speedo go to 0. The dash chimes every time it does it. Every light comes on the cluster. Signal light indicators on dash dont work but the exterior lights work fine. Then for a split second you can see the message no bus flash. I'm at a loss with this. Truck runs, starts fine. Dosent create any other problems but a real annoyance. It comes and goes. Sometimes wont do it one day, then the next it's none stop. Every 3 to 5 seconds the chime, and the lights and tach and speedo going to zero. Any help much appreciated!!!
  • Replies 3
  • Views 2.1k
No codes but I haven't done the hold the trip reset and turn key to acc. Yet to look for c codes. It's something with either the cluster itself or something on the can bus. Maybe the radio deck? I'm not sure what else runs off the bus.
