Torque converter lockup
- Replies 9
- Views 5.1k
If you have a single disc converter (which, at $600, you do...), I would not run anything but ATF+4 in it. you'll need the friction modifier to control converter clutch chatter. I don't re
Hey guys, My wife and I moved an hour and a half from my home town, and on the three trips it took to move our stuff, the TC unlocked, and I'm not exaggerating, probably over 1000 times each way. I f
Hey fellas new here. I’ve got a 2000 24valve vp truck and the trans has been rebuilt. Receipt says reman billet converter. From time to time I have lock/unlock issues pretty sure it’s the alternator wire. Problem now is the truck is easing into lockup, shuttering, rpms just fluctuating at lockup. But it only does it under moderate to heavy throttle but converter locks up fine under full throttle. Doesn’t matter if comp box is off or on level 5. So is this converter issues, valve body issues, voltage problem or what?
