- Replies 4
- Views 2.9k
Popular Days
P0216 is a timing issue with the pump often caused by overheating the electronics due to low fuel pressure from the lift pump. There are a few other causes of p0216...AC noise from a bad alternator,
Your need to maintain minimum 14 P.S.I. at all times even when hauling heavy uphills, accelerating etc. Add some 2 strike oil and get the fuel lubricity within Bosch specs for the VP44. Most of us wit
My 01 started running a little rough intermittently. It did it once and quit. Hell I thought it was a glitch but about 3 weeks later it was running rough again. I changed the fuel filter with no change. Then I changed the lift pump and it ran better but not good. I wasn’t having any issues with it starting at all, just randomly would get loss of power. At this point I was still driving it to work but it was getting worse. You could turn of the key going down the highway and boom it would run good again, maybe for a minute or the rest of the day. It finally got to where it would take a few minutes to start so I went ahead and changed the VP44. It ran perfect for 2 days and now it is back to hard starting and has a loss of power as soon as it shifts gears. Only code currently is the P0216. I checked grounds and all looked good. I’m a newbie and don’t have a clue as y’all probably can tell by now. I got the VP44 from thoroughbred diesel! Blow my little pea brain and tell me where to go from here! Thanks
