Po234 and 236
Installed new edge Ez since my last one quit working. Now I have a problem where it goes into limp mode after too much boost I think? What’s causing this? Stuck wastegate?
  • Replies 1
  • Views 1.3k
Popular Days
  • The engine when you exceed about 20 psi of boost. Sounds like the EZ is not boost fooling. It should. I would contact Edge and see what they say. Should have said the engine will defuel when 20 o
Should have said the engine will defuel when 20 or so psi is exceded.
