Anyone know the size of the rear passenger ebrake cable for drum brakes is? I'd take it off and measure it but seeing how this truck is my daily I can't really take it off and measure it or I'll be without. Anything helps, thanks!
  • Replies 7
  • Views 1.3k
4 minutes ago, Dieselfuture said:
Can you stop at the parts store and grab one see if it matches?
I was gonna order one off rock Auto cause there seems to be like 4 different sizes. Didn't know if someone had the size offhand or anything.
You don't have to buy it at parts store. But if it matches the length, you could get the part number off it
Guess I had a brain fart, I meant to include I was going to buy it off rock Auto cause it was cheaper, I don't know why I missed that info....
Part # 18P2711 I ordered this from Rockauto 101-1/2 in Thru vehicle manufacture date of 7/4/00, You know when your Truck was built?
9/00. Has the updated front axle.
I would order the one for 7/5/00 and later. They must have really changed the way the cables run starting 7/5/00, looks like rear right are around 45 in. vs the 101-1/2 up to 7/4/00 I would go to https://www.factorychryslerparts.com
Think this is the one you need BC96951 corresponds to OEM part #'s {#52010030AA, 52010030AB} 7/5/00 and later
Edited by Blueox01
