2001 cummins ecm terminal
I this the correct terminal to use in the ecm on a 01 cummins? #20 deustch connector.
  • Replies 1
  • Views 1.4k
    Look like it could be but the only way to find out is to pullan exist pin and look at the dimensions. You might call Auto Computer Specialist and ask them which terminals are used in rebuilding the so
Look like it could be but the only way to find out is to pullan exist pin and look at the dimensions. You might call Auto Computer Specialist and ask them which terminals are used in rebuilding the socket for the ECM on your truck.
