- Replies 3
- Views 977
dripley 2 posts
Towrigdually 1 post
i see that my truck already has the connectors in the doors for power mirrors and the control switch on the drivers door.
do I need to do anything other than get a mirror control switch and a set of power mirrors to do this?
Would it be the same for heated also? Pulled back the ac/heat controller and the wires are plugged into a empty spot on the controller.
Is there a need to put in a fuse in one of the empty spots on the fuse block inside the cab or is it all powered already.
thanks
