- Replies 4
- Views 1.1k
Bforeman 2 posts
dripley 1 post
CUMMINSDIESELPWR 1 post
So today I installed a brand new quad Adrenaline v2 with iQuad I drove the truck for 3+ hours with no issue with pedal response.. later on in the day while driving the volt gauge bottomed out. I pulled over looked over everything and it all appeared fine. I went a few places with shutting the truck off and starting back with no issue. I get home truck sits for 1+ hours I go out to install the egt probe after getting required bit and tap. I start the truck to a CEL I pay no mind as I idle into the garage. After I install the egt probe I start the truck and go to give it throttle with no response I check the DTCs to find the P0223 I follow mopar mans diagnostic with no luck.
