- Replies 5
- Views 1.4k
dripley 2 posts
J020MA 2 posts
Royal Squire 1 post
Alright so I've got this 24v project im working on - don't have any exp on them and I heard this is the spot to go...
Trucks got p1689 flashing, p0113 codes. Previous owner said it "wouldnt go above 20km/h". I havent tested that theory because I suspected the lift pump. I have a FASS100gph & set of glowshift gauges going in this thing shortly but I wanted to confirm the source of these codes before i mess with them. I also am having, what I believe to be the sending unit act up on me. Fuel gauge at E, but when I disconnect / reconnect connection at top of sending unit it jumps up to half then slowly climbs down. Tested the gauges on the dash, and fuel gauge reads fine on that test. I put fuel in it when I thought it was on E, and it overflowed. So I'm sure it's the sending unit. Anyways looking for some advice on te p1689 and p0113 codes.
What I've done in terms of the diagnostics -
confirmed vp44 is good by wiring it to the battery from pins 6&7 and idling
Steps 1-3 on the P1689 8 step diagnostic thread... Having trouble accessing the ECM connector so I think I will remove the pump filter and install the FASS before I test that
Hoping you folks with all the experience can help out
