- Replies 9
- Views 1.9k
I believe you are mating two incompatible wiring harnesses. The '98 was set up for "+" switching of the lights (constant ground at the lights) and the 2001 is set up for "-" switching of the lights (
I swapped my 1998.5 drivetrain and engine wiring harness into a 2001 1500, all fuses and relays are good, I only have reverse, turns and hazard lights the rest of the lights do not work including dash, tail, running lights and headlights. The high beam indicator on the dash always stays on no matter what. I have ground to all lights just no power any ideas?
