Apps sensor
The APPS sensor has 2 Idle validation switch pins, pins #2 & #6 anybody know which is Idle ON and Idle OFF(or Throttle ON)
  • Replies 6
  • Views 2.7k
Thanks alot,were do you get all these diagrams? That's how i wired it but just wanted confirmation.
Dodge Factory Service Manuals is where I got most of them... http://forum.mopar1973man.com/downloads.php And yes that's exactly how the APPS sensor is wired to the ECM... Take notice there is NO direct connection to the PCM. This why I don't suggest doing the voltage adjustment like most sites/forum suggest because it will make matter MUCH worse!
I bought a sensor like Timbo sells and wanted to make sure i wired it right,the diagram for the sensor i bought has a IVS Idle Active and then IVS Throttle Active. But your saying NOT to ADJUST the voltage like he shows on his web site?
I'm talking about this old write up which is wrong... http://www.cumminsforum.com/forum/98-5-02-maintenance/357-apps-reseting.html Which explained here... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/apps-adjustment.htm As you'll find out I got a full instructions on Timbo install... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/timbo-install.htm
Yea already read it all,just was'nt sure on those 2 pins but got it right,just wanted confirmation
