Need some help with iquad please
- Replies 11
- Views 2.1k
Cliffordrules 5 posts
Dieselfuture 3 posts
Me78569 3 posts
Good day Gents,
I have recently purchased a 1999 Dodge with 5.7 Cummins 24v and it came with iquad adrenaline "aggressive" setup. The vehicle had 275hp injectors which i replaced with 50hp just last week. When i first got the vehicle the programming did not seem to work: no matter what the setting, the power output was the same and fuel economy sat at around 14mpg. With the new injectors, there is now a definite response from the different program settings however, the milage has not changed one bit even with the lower hp injectors and a full tank of babying the throttle.
I have read through quite a few of the posts, i appreciate your knowledge and willingness to help: i need your help with:
Making sure I have chosen the correct vehicle as there are at least four options for a 1999 2500. Second, after browsing the forums I saw moparman's custom tune for daily driving, i attempted to input this into my phone's app but it did not have all of the same parameters. It was missing options for selecting: 6 degrees of timing, low boost scale at 25% and an option for fuel load timing 2
Appreciate your help,
