Fluid in transmission solenoid assembly
- Replies 6
- Views 3k
The pass through connector is leaking internally and needs to be replaced.
The pass through connector comes as part of the OD/TCC solenoid set.
Is fluid supposed to accumulate in the transmission solenoid that is attached to the xmsn housing? I have attached the diagram of the connector which plugs into this solenoid, I have cleaned out the plug a few times but fluid keeps re-appearing.
Just seems weird that have fluid in a electrical connector. the Main 8-plug connector attaches to the solenoid in question. I did some quick searching and could not find out any information on if this is/is not normal.
Edited by jtrakel
