Is this clutch engagement normal?
- Replies 8
- Views 4.6k
Mopar1973Man 4 posts
01superb 4 posts
I just purchased an 01 2500 6speed 4x4 Cummins and I’ve noticed after driving it for a few weeks now that if I start in 1st gear, let up on the clutch a couple inches it quickly engages and gets moving no issue. If I start in 2nd gear, it starts to engage at the same distance from the floor but as I keep letting the pedal out it doesn’t seem to grab any more until I get to the top of the pedal travel then it grabs fully and takes off at the last little bit of clutch pedal travel. Starting in 2nd there isn’t any pedal travel after the truck is fully in 2nd gear. Also at rest there is an inch or 2 of free play in the pedal, I can lift up on the pedal with my foot as it is just sitting there. Is all this normal? It doesn’t slip under any conditions per say. I had a 6 speed Cummins years ago and I don’t remember starting in 2nd gear having the same feel. As far as I know this isn’t a performance clutch in this truck and my old one was said to have an upgraded clutch. Is this normal for starting in 2nd gear though? It seems to me since it starts to engage soon that it should fully engage much sooner in the pedal travel than it does.
