Trouble on the horizon?
- Replies 3
- Views 2.2k
Mopar1973Man 2 posts
dobienut 1 post
A few weeks ago, actually the day after that I had my flash done for high idle , I was going to town and experienced dead pedal for about 10 seconds and it threw a P0237 MAP Sensor Voltage Too Low code and tripped the engine light. This morning on my way to town I once again got hit twice with it lasting about the same amount of time, maybe a bit longer the second time. All three times were into a hill and I want to note that all times this happened was on a relatively cold engine.This morning it never tripped the engine light and I checked and I have no codes at all. First time I thought maybe it was map sensor just from where I had unhooked my programmer for gettting my flash done and then hooking it back up later, maybe a loose connection or something. I'm holding consistant 16 psi on the VP, no hard starts or anything out of the ordinary but this. Vp going out or possibly, map sensor issue, or something else? Wondered if I should start at the cheap stuff before hitting the big one
