Any clue what happened?
- Replies 5
- Views 3.4k
cummins2k 2 posts
Mopar1973Man 1 post
MnTom 1 post
ISX 1 post
To put it lightly this hasn't been my best week but I did finally get a full day off from both jobs so I decided to do a few things around the house. I had repaired a leaky main water valve and went to see if it was holding up good still (it was) when I ran across this.
It almost looks like a mouse chewed on it. Normally it is fairly dark in this corner because the one light in the crawlspace just doesn't get this far but I had thrown a drop light in there when I noticed it. The wire was 12-2 Romex running to a dish washer the previous owner had installed. When we first bought the house the dish washer would leak due to whoever installed it running screwed through the sides (I guess they figured you mounted it this way?) Of course this water would slowly run down through the hole in the floor were the romex entered. This is probably what caused the corrosion.
Either way I decided to throw caution to the wind and fix it since I was bored so off to the hardware store I went. Mind you I am not an electrician, just watched good ol' Dad wire up a few houses and did a little reading before starting.
I decided not to run Romex like the previous owners did rather I went with a flexible metal conduit and 12 gauge THHN/THWN wires. I terminated the good part of the original romex in the crawlspace and installed a junction box. Then ran the flex conduit up through the floor. At the junction box I connected the wires with nuts and wrapped them with colored electrical tape dependent on whether it was a hot, neutral, or ground. I secured everything with appropriate clamps and anti-shock bushings then finished hooking up the dish washer.
When I flipped the breaker there weren't any sparks, glowing, funny noises or anything and the dish washer worked just fine. No it's time figure out what chewed it and how it is getting in.
