Stock Ride Height (springs)
- Replies 3
- Views 2.8k
Popular Days
Soon as you said your truck drives weird my mind went to castor settings. Weird and wandering in my mind go hand in hand. I'd adjust castor more positive if castor washers aren't alr
Some info here: https://mopar1973man.com/topic/18070-can-someone-help-with-factory-height/ This set might work. https://www.napaonline.com/en/p/NCE2775414?partTypeN
I cannot locate in the FSM what the stock ride height should be, and by that I mean from frame to axle as that won't change with tire size.
Can someone out there measure for me, or know what it's supposed to be? The previous owner had a snow plow on this truck, had 36k pound tags, and clearly used the gooseneck a LOT.
I have tight suspension and recently had an alignment done, but the truck still drives weird. My frame to axle dimensions are different from passenger to driver's side.
Considering a new set of front springs, but open to suggestions. I have not checked the rubber isolator in the last 50k miles, but was there when I changed the shocks - obviously that doesn't mean it isn't trashed.
EDIT: Also, input on variable vs. constant spring rate, and manufacturer would be appreciated. MOOG CC1710 are the variable, but listed as only being for standard cabs - MOOG apparently doesn't make Quad Cab springs of any kind. 7394 is the constant rate part number.
Edited by LorenS
